1 - 10 of 10 Posts
Plugs look the same, but i dont know about the orientation of the pins, i bet it would if you could find a wiring schematic of that one and ours and make a harness if u had to, or could be just plug n play either way its a good price
Factory Fresh
It might work but it might not fit your dash trim. The H3 dash is completely different to ares thats why it has the silver face.
It will need to be unlocked in order to work with your truck... As already stated... Good luck on getting it working... Have you thought about a aftermarket unit... Getting that one unlocked would go along way towards buying a new H.U.
Discussion Starter #6
How much would it cost to get it to work in my truck, and where would I do that at? I was planning on getting an aftermarket one until I saw this, I just hate aftermarket ones with a passion. They all look like shitty China special plastic, you can't easily dim the bright ass LEDs, the stupid plastic shroud never looks good, I see my friends resetting their presets and settings basically every time I see them, and they're just ugly overall. If I could get this to work for relatively the same price with little to no modification on the bezel, I'd rather use this.
If that unit will actually work in your truck (I don't know if it will or not), it costs like $30-$50 to program it from your local GM dealership. The unit needs to be programmed based off your VIN.
That's the basic cost to get one stereo to work in a different vehicle.
Also, there are some good install kits out there. I have an aftermarket in mine and it looks pretty clean, in my opinion.
Discussion Starter #8 (Edited)
Just looked @ a few pics on Google, and that appears to be an LED to help in loading CDs, not an AUX port. Thanks for the help anyways, looks like I'll just get a Kenwood or something...
My Kenwood looks like it came OEM ...
1 - 10 of 10 Posts
