1 - 6 of 6 Posts
I'm just trying to see if my 2011 stock z71 rack will work on a 2wd coil front end , yes I know the power steering lines were diffrent for diffrent years but say I had a 2011 2wd z85 would my rack work on it
I have tried slightly to look up part numbers to compair but nt having much luck some say z71 than some say they work 2wd and 4wd with the same part number , I'm sure the zq8 rack is a diffrent number sense I think they have a quicker ratio
Thanks in advance
Only info I can offer is the the mayhem metalwork's rack and pinion bracket fit my z85 2wd with no problem, so I would assume the mounting points are the same.
Monkey Slut!
Believe it's just the shafts for the tie rods are different. Remember Kevin from Slick & Dirty saying something about the input shafts being different on the Z71s.
Discussion Starter #6
1 - 6 of 6 Posts
