1 - 20 of 43 Posts
S
Is the ZQ8 shocks softer than Z85? Are they the same length?? My stock Z85 ride sucks.
S
So, rrcn do you know if the ZQ8 shocks are less stiff than Z85?
edward all the front shocks are identical on the coil spring setups. their is only one part number, so regardless if its z85, zq8 or xtreme they all have the same front shock. the rear shocks are differant though, i would guess stiffer on the zq8/xtreme.
shocks to lower a truck? I wish!
The ZQ8 and Z85 shocks have the same rebound rate. The differance between the two is the ZQ8 has the 1" drop in the front and rear via the springs and the ZQ8 has the standard rear swaybar.
So with that said the front shocks are interchangable between the ZQ8 and Z85, and the same goes for the rear.
Jeremy
Jeremy
rear shocks are actually differant between the 2. differant part numbers. im sure its because the zq8 has the drop so the travel is differant.
not the stock ones atleast. the belltech's are the only lowering shock.
Well, yeah, I was referring to the stock ones since that was the question at hand. ;)
And you're right, the rears are different.
I had pics of ZQ8 and Z85 rear shock comparisons somewhere, can't seem to find them ATM.
I'd like to add stock shocks suck lol. But they are made by KYB not delco.
what kind would you reccomend?
Fuck I don't even know, theres really only 2 companies that make front shocks for us and thats Monroe and Belltech of course the Belltechs are lowering shocks and more expensive. For the rears you can use S10 rear shocks so there's plenty of options there.
Question is, what are you going for? Sounds like your complaining about the shocks being too stiff or harsh right? Well these aftermarket shocks are going to be much stiffer so as far as wanting softer shocks it don't get no softer than stocks lol.
You could try lowering your tire's air pressure down to 32 to 30 psi and see if that helps.
S
Discussion Starter #20
wouldn't that kill my gas mileage? I keep them at 33psi
1 - 20 of 43 Posts
