I've put a lot of work into the truck over the past few years and I figured a lot of you might be interested to get some ideas for your own builds. Quick summary of what's been done: 2.5" suspensionmaxx lift front, '85 c10 leafs and 2" shackles in the back, 31x10.5r15 BFG A/T KO2 (for now) on 15x7 rims 4" backspacing, G80 installed in the rear end with 3.73 gears, crossmember notched for clearance, glasspack exhaust, 5 speed swapped, Badlands 5000lb winch, 22" lightbar, custom welded front and rear bumpers out of 1.5" sch40 pipe, custom front skidplate, turbo.
Specs on the turbo: T3/T04e 50.5mm turbo, 60lb Siemens Deka injectors, manifold welded out of 2 elbows and 2 T's of 1.5" sch40 pipe with the turbo flange out of 2 3/4" pipe cut in half and rewelded to fit the opening, no intercooler, preturbo water injection using a coolant overflow tank, washer fluid pump, 4psi oil pressure switch, and a 2gph mister, oil feed from an oil filter sandwich plate, drain is 3/4" tubing and barb into the front of the oil pan, tune by LimeSwap(highly recommend).
Note: Turbo was $120 on ebay and I only spent $1000 total with tune and parts. (Did all this in highschool, not a huge budget but learned a lot)
I'm happy to answer any questions about how/why I did what I did or where I got parts, etc.
