Hey Howzit,
So Just to say it, i'm wondering how ofter the Camshaft Position Exhaust Actuator (the actual sprocket on the exhaust cam) is a problem for folks, not the Camshaft Position Exhaust Actuator Solenoid. I have replaced my solenoid with "the good kind" and no change. Some back story, I did a cylinder head replacment, soon after buying the truck with 97K miles on it due to a hole in the vavle of number 1 cyclinder, and after putting the truck back together it ran terriable. tore it back apart everything looked good so found that the Camshaft Position Exhaust Actuator was stuck. When bench tested with compressed air the actuator did not twist (even with hand pressure) and ending up popping apart (several gears with springs are inside). Ordered a new Camshaft Position Exhaust Actuator, replaced and truck ran much better, however after about 300ish miles i got the dreaded P0017 code. Since the truck was not running terriable i lived with it for about a year now. The big headache with the truck is the oil consumption. It burns about a quart every tank of gas, i'm amazed that it doesn't pump out blue smoke on the regular but it does occasionally puff a little. Found myself with some free time so i have tore back into the truck. I was very interested to see if my chain was streached and used Millstone's post of South Main Auto Repair to compare: www.youtube.com/watch?v=0pkIZKys2cE&feature=youtu.be. So it might be slightly streached but more alarming was that the TDC didn't seem to be synched with the cams for the first cyclinder, which spark plug was fouled. the other four plugs looked pretty good. So i had the bright idea to bench test the "newer" actuator again and again it was stuck, and again it exploded on the bench and again i have ordered another. Little at a loss for why this is happening, i am doing what i see in the video to test the actuator with compressed air (although i will definatinaly back off on the pressure if there is ever another next time I was at 50psi). I know these parts are remanufactored but i guess i wonder if anybody else has run into this problem? I'm scared to test the "newest" one before i put it back into the truck, (these are like 160 bucks a pop after the core). I tried to reassemable the actuator while no luck (anybody with the inside track on that feel free to chime in)Also since the truck wasn't really running that bad i wonder if this could even have been the orginal problem?
TL;DR: How often have your cam actuator fuked up?
Thanks
Thanks
