How To: Lift the truck using Shackles and Torsion Bars
83K views 91 replies 30 participants last post by  08Canyon
Gawillet and Popgoesdaweasel16
Project Name
How To: Lift the truck using shackles and Torsion Bars
Project Description
To lift your truck using shackles and the torsion bars. Note: Not all Colorados/Canyons are equipped
with Torsion Bars, only the 2WD and 4WD Z71s and the 4WD Z85s have Torsion Bars suspensions, the 5.3L 2WD Z85 also uses Torsion Bars suspension. The others have
coils.
Skill Level
Moderate
Make: Chevy/GMC
Model: Colorado/Canyon
Year: Any
Engine: Any
Power windows: No
Sun Roof: No
Tools Needed
Bricks/Pieces of wood as stops
Floor Jack
Jack Stands
Ratchet/Sockets
1 1/16” Socket (for Torsion Bar adjustment)
3/16 Allen Wrench
Impact Gun (not required, but immensely helpful)
Vise grips or pliers
WD40
Copper anti-seize (to re-grease shocks and shackles)
Project Time
1 hour or less
Project Cost
shackles 120.00
Rancho 5190 shocks 51.00 each optional
Differential spacers, set of 4, contact Larry @ 1-888-MAXX-CAM.Price is scheduled to be $45 + shipping.
Chevy Colorado 2wd MAXX Shackle - Rear (2004-2008) | Chevy | Suspension MAXX | Suspension MAXX
1. Remove the Spare tire with the kit available under the passenger seat. Assemble the kit, crank the rear tire
down and remove it.
2. Loosen the lugs on the front wheels, jack up the rear of the truck, and place a jack stands under the frame on
each side of the truck and remove the wheels (See Figure 1 for jack point).
3. Loosen the rear shackle bolts with a 3/4 in wrench and socket.
4. Use the Jack to raise the rear differential to take the tension off the springs. You’ll know when you’ve raised
it enough because the shackle will become loose.
5. You should now be able to remove 3 of the 4 bolts from the shackles. Use a hammer to knock the bolts out.
I used my 10” socket extension to help remove the bolts from the holes. You will need to lower the rear
differential some to allow for the bottom right shackle bolt to clear the exhaust pipe and allow you to remove
the final shackle bolt.
6. Remove the bottom bolts from the rear shocks using a 3/4” wrench and socket (Save these bolts and nuts, you
will need them to install the new shocks).
7. Remove the top bolts of the shocks (2 bolts per shock) using a 1/2” socket and the 10” socket extension. The
shock will just fall off so watch yourself (Save the bolts to be reused when installing new shocks).
8. Now we are ready to install the new shackles. Grease the holes of the shackle with some anti-seize. Insert the
top bolt and hand tighten the nut. After you’ve got the top bolts in each shackle in, adjust the jack up or down so
the springs line up with the bottom holes of the shackle. Insert the bottom bolts and hand tighten
9. Install the rear shocks using the bolts you used from the stock shocks with a 3/4” wrench and socket for the
bottom bolt and 1/2” socket and 10” extension for the top bolts. I used Rancho 5190 shocks. Use anti-seize in
the bottom shock bolt hole.
10. Reinstall the spare tire.
11. Lower the jack holding the rear diff off the ground.
12. Tighten all the shackle bolts.
13. Jack up each side of the truck in front of the rear leaf springs one at a time and remove the jack stands. Now
you’re done with the rear end!
14. Raise the front of the truck until the front wheels are off the ground. Place jack stands under the frame and
lower the jack. The Torsion Bar is located under the truck half way down the front doors (see Figure 6).
15. Use a marker to draw a straight line running from the center of the bolt to the frame so you know when
you’ve made one complete rotation (see Figure 7).
16. Use a 1-1/16” socket to turn the bolt clock wise (right) to raise the front end of the truck. I started by doing 5
complete turns on both sides. Lower the truck back down to see if the height is where you want it and measure
to make sure each side is equal. After the original turns, I was easily able to turn the bolts with the truck on the
ground. I proceeded to turn the passenger side 1 more turn and the driver side 1-1/4 more turn to get both sides
equal and the height where I wanted.
17. Support your diff and remove all four bolts. Next lower the diff about an inch, slide in the spacers and reuse the factory bolts. This serves to correct the new CV shaft angle and lowers the diff which lessens the halfshaft angles,otherwise you will damage the CV boots.
18. Now, we’ll install the new front shocks. You don’t need to lift the truck up to replace the front shocks but it
does make things much easier. Remove the bottom bolt from the shock using a 3/4” socket and wrench. Save
this nut and bolt for when you install the new shock.
19. Remove the top nut using a 5/8” wrench and 3/16” Allen wrench. The Allen wrench fits into the top of the
shock bolt. The shock will fall out onto the ground. You don’t need to keep any parts from the top of the shock;
you will NOT be reusing them.
20. Install the new shock. Grease the lower bolt hole, and install the lower end of the shock into the mounting
location, reusing the stock bolt and nut. Install the top nut using a 1/2” wrench and the supplied hardware that
came with your new shocks. Install the rubber bushings and metal plates the same way they came off. Use vise
grips/pliers to hold the top of the bolt to keep it from spinning and tighten down the nut as much as you can.
21. You’re done, now get a front end alignment and you should be fine.
#6 · (Edited)
Question? Is that your truck? I've read this article before, quite a while ago. :D
Sorry for the skepticism, but there is a picture missing from this how-to from the original one that was posted 5 years ago. The missing picture is a truck plated in a different state than Arizona.
#7 · (Edited)
Gawillet is the original author as listed on the how to and is from Michigan. He is also a member of the nation. The differential spacers were added to the original along with a picture from mwcky illustrating the need for and location of the spacers. Parts, costs and sources were not listed on the original. No pictures were deleted unless you have a different version. Is there an issue with the how to?
#10 ·
Not sure if there is an issue, but I read a similar writeup on CFANS that was posted by somebody else (Gawillet) back in 2007.
I just wanted to be sure somebody didn't copy/paste from there to here to take ownership of the how-to.
Seems to be on the up and up I guess.
#11 ·
It is from gawillet off of c fans and in the 'How To Posted By:' section at the top, it says gawillet
Sent from my iPod touch using AG Free
#16 · (Edited)
Yes I am the original author of this write up. I did this write up for Cfans NOT 355 Nation. I'm not going to tell you to take it down, but out of respect for myself and Cfans it would have been nice to get an email asking permission before you simply copy and paste my photos and write up on your site. not cool guys! If Cfans has an issue with this I'll let them tell you to take it down. I put in a lot of time and got a lot of advise from Cfans to help me do this write up. If I wanted it posted on 355nation I would have done it myself.
#17 ·
So the shocks are not necessary? And I have heard that you need to get your truck aligned after you tighten your torsion keys, is this true? Also, are the differential spacers required or is it just a precaution, even if I only lift about 1-2 inches?
Great write up by the way!
#18 ·
Nope shocks ain't necessary but surely help out the ride after tb's are cranked, and yes I would recommend an alignment. Mine was thoroughly screwed up afterwards (didn't do equal twists but i also twisted the hell out of them using a leveling kit) and it helped getting aligned. I'm sure 1-2 inches will be fine
#22 ·
Longer shocks in the front are not required. My fear would be longer front shocks will always be running in the compressed state.
If the shocks are progressively valved, you will not take full advantage of the shock absorbing properties. I don't know if Rancho's are progressive though.
If you need shocks now, just get some cheap shocks that work for your needs. It happens quite often, that "I want to eventually get a full lift" and doesn't happen. If you aren't lifting within 2 years lets say, just buy shocks now for today's truck. Otherwise, you will end up putting on a lift kit in the future and installed used shocks (essentially).
My feeling is that running the proper equipment now is more important than trying to save a few bucks at some point in the distant future.
#26 ·
Can you take a picture about what you're talking about? I did this exact procedure with my 2006 Colorado back in 2007 with no problems clearing the exhaust.
