1 - 1 of 4 Posts
harnesses and communications with the other modules in the truck...(if your using cluster, ABS, Body module)
Emissions will be a stickler most states don't like older engines in newer cars.
new upholstery because your gonna ruin the old with the fun...
your guess is good as mine on that 5.7 pan fitting. may need a street rod, Colorado, Hummer pan.
accessories should be good. not sure about the mounting bracket/configuration.
the 5.3 was a option for the 2009-2012 Colorado's so stock parts are out there.
the 5.3 swap and 5.7 swap should be the same effort.
factory mounts available
factory exhaust available
1 - 1 of 4 Posts
