New Owner of a Rare 2009 5.3L V8 ZQ8
Tags
5.3l v8 zq8
315 views 6 replies 5 participants last post by  Sam!
New to the 355 platform, figured I'd try my luck here versus Facebook...
So I bought this 2009 GMC Canyon 5.3L ZQ8 from the Midwest, had 230k when I purchased it, now almost has 240k. From what I've learned this is a very unique/rare spec Colorado/Canyon, 1,109 built total, 150 crew cab Canyon built in USA total. Although rare, this truck was severely neglected and mistreated. Previous owner let every single warning light shine on the dash, wrong size wheels/tires, and no power steering at all. Truthfully, I think I paid too much, $7,000, but I knew the chance of me finding another surviving example was slim to none. What makes this one even more special is that it is a 2009, so no VVT.
It took a lot to sort out this truck, but I knew I couldn't build a running and driving example (that was also emissions legal) for less than $10,000. The owner sold it to me without the hideous aftermarket wheels, here it is home with 17in wheels and bald tires...
I wanted to make it more original so I sourced some Enkei 18in ZQ8 style wheels.
The previous owner cut out the rear cats and also straight piped the muffler, I don't have pics of the exhaust but it cost a lot and took multiple trips back and forth to 2 different muffler shops to get it done right. It's now quiet and such a sleeper. Next I needed to pass emissions so I replaced the EVAP vent solenoid.
Having the bed lifted made the job easier and it just barely passed emissions. The day after passing its 1st attempt, the check engine light came on... but it's good for another 2yrs! The power steering pump was also replaced along with the serpentine belt. I also did the rear shocks while the bed was lifted.
Now unfortunately, the truck has some bad rocker rust, and i noticed some rust holes in the bed floor under the spray on liner... to make it worse, I did see a spot in the frame that wasn't visible during purchase of a rust hole starting in the frame.
Soon, I'm going to tackle the rocker rust myself, and later down the road I'm thinking of possible drivetrain swapping it to a cleaner body... possibly a Regular Cab...?
#2 ·
Welcome.
Yeah get after that chassis issue before it gets worse. Make sure it is sound before you put too much effort it to it. The area at the front leaf spring mount, especially on the LH side is where we have trouble. Is that where your hole is forming?
By the sounds of it, it was an upper mid west, which means rust belt. The rocker issue is pretty common too, unfortunately. Best way to get after that would be to cut out the rusty sheet metal. Find a decent donor, and weld the solid metal back in after you have rust treated the inside area of the rocker. Finally spray the snot out of it, on the inside, with Fluid Film to keep the corrosion working at a slower pace.
Now that it is in caring hands, you can work to get it back in shape. Wont be able to undo all of the neglect over the years, but if you can patch up what you need to, and hold station on it with maintenance you should get enough years out of it to make your investment feel better.
#3 ·
I'm leaning more towards finding a body donor for the truck to be honest... on top of the rocker rust, previous owner said a deer ran into the side of the truck, near the fuel cap area, dented that part of the cab along with the door. It has a sunroof bit it no longer works, thankfully it doesn't leak.
I think the ZQ8 suspension, V8 drivetrain in a regular cab would make this thing pretty quick. But we'll see, i'm keeping my eye on the auctions.
#4 ·
A reg cab V8 would be super cool. ZQ8 reg cabs are not super common either, as most are Z85 work trucks. But if you can stumble upon a southern truck with that chassis it will be a great project. If yours is 4wd that makes it tougher yet. A new crew cab body would be an easier find, and while its apart you will be able to mend the chassis. You got options!!! Fun to be had.
