Reset the airbag light
16K views 4 replies 4 participants last post by  rangerbob
Anyone know how I can reset the airbag light? Can I pull the battery cables or do I have to go to the stealership?
Thanks!
#4 ·
The truck checks the airbag system upon startup every time. So if there is a problem you know about with the wiring or something YOU did, the only way to fix it is a bypass or fix it. :lol: Then re-set the system and it should turn off.
#5 ·
Ok. Looks like I'll be pulling the battery cables.
