smaller tires and wheels
1.4K views 7 replies 5 participants last post by  08Canyon
I have 235 50 18 on my ZQ8 and found a smokin deal on some 215 70 16's. Will they fit and is it a problem for the computer/ speedo to run 13% faster? They're new take off winters with rims for $400!
#3 ·
~.6" taller. you'll be fine.
i went ~1.5" smaller (steelies to zq8's) and im good.
tires mess with me because at a slower rate you may be the same speed but the faster you go the more its off. its not just a set number.
but again, you'll be fine.
#8 ·
Right, TPMS doesn't work off diameter, pressure only. Either you don't have sensors in the wheels or they are over/under inflated. Can you check with a local tire shop to see if you can have them reset, as if you had them rotated.
