Stock and Aftermarket Sway Bar Spec's
51K views 67 replies 37 participants last post by  Hawaiian_Built
  • Stock Sway Bar Spec's
  • Stock Z85- Front is 1 1/8" in Diameter and No rear sway bar.
  • Stock ZQ8- Front is 1 1/8" in Diameter and the Rear is 7/8" in Diameter.
  • Stock Z71- Spec's coming soon.
    Sway Bar Endlink's
  • Factory Front Sway Bar End Link - Part# 15196366
  • Factory Rear Sway Bar End Link - Part#
  • ** Better Choice- Moog Greaseable Endlink **
    Front Driver Side - Part# MOOG-K80582
    Front Passenger Side - Part# MOOG-K80583
    Rear - Part# MOOG-K80611
  • Belltech- Front is 1-1/4” in Diameter Part# 5421
  • Belltech- Rear is 1" in Diameter Part# 5521
  • Belltech- Sway Bar Set Part# 9900
    Click Here for Belltech's Site
  • Hellwig- Front is 1-5/16" in Diameter Part# 7679
  • Hellwig- Rear is 1" in Diameter Part# 7680
    Click Here for Hellwig's Site
#2 ·
Excellent post Brewer.
Another nother thought; the BellTech rear sway bar WILL work on a ZQ8 if you take the time to cut the factory swaybar mounts off the axle. I have personally done this.
#7 ·
Yeah these make a big differance!
In hard corners it will lift a rear tire!
#13 ·
To a point yes, less sway in the front will help!
#16 ·
Yeah between the bar being thicker and better bushing, you will feel a differance!
The rubber sway bar bushings were shit after 30k miles!
#19 ·
It should be!
#20 ·
hey for my z85 what mods am i gonna have to make to install the aftermarket rear sway bar? i havent checked but dont recall noticing one back there, so are there the proper mounting points or??
#22 ·
Yeah the front is a direct fit and the rear you need to cut the factory mounts.
#25 ·
yeah but idk if i've even got any mounts under there. damn this snow i dont feel like looking... i'll use the gfs garage next time i'm over there and take a peek.
#26 ·
belltechs site says it will fit a z85....so i'm assuming i'm set there. but the front says "only for vehicles with coil spring suspension" are the front sway bars diff on a torsion bar truck? they dont look it...
