I didn't say should have used skyjacker, I said call them and order the sway bar endlink mounts they have because they offer individual pieces of the lift it's just a little pricey. But if you can't use the sway bar in the stock location then that isn't an option.
no no not you on this, people have told me that skyjacker lets the superskidz plate mount right up no problem.
As far as removing the sway bar you mean allstate as in an insurance company? Plenty of people remove sway bars and I have never heard of any claim denied for not having one, some vehicles don't even come factory equipped with them. If you tell them then that's just plain stupid.
They consider it factory installed safety equipment and told me if I get in an on-road accident without it they won't pay for damages.
As far as the skid plate, it's only sheet aluminum and anything that is really susceptible to damage now has 2 crossmembers underneath it and the skid plate isn't going to really do anything protect them. I've had my truck 8 years and 5 of them have been lifted and wheeled regularly with no skid plate and I have only bent tie rods and worn out ball joints.
The bottom half of our front bumpers are just plastic that isn't really going to stop anything unless it hits a frame rail on the way under. The skid plate can help keep your radiator and transmission lines intact during an animal hit (which is more what I worry about in upstate NY) and I have an external transmission filter and cooler installed so I have lines that used to be covered by a skid plate now exposed during something like that.
I'm not as familiar with the Rancho kit's swaybar setup, but I'd be surprised if nobody has installed Superskidz with Rancho.
I had to add some spacers and install some blocks with tapped holes to get the Skidz to work with my Skyjacker kit, but it did not require any serious re-engineering.
Rancho kit is angled and there are no points to use to attach the skid plate under the crossmember. The people who have used the skid plate with Rancho have mounted it under the drop crossmember to the original factory mount points - so if you hit something and it works it's hitting your crossmember as you run it over.
Their's relocates the whole sway bar down 4". Seems like it would be easy enough to just put the sway bar back on the frame how it was stock and run 4" longer sway links like the other guy had said. Personally I hated how mine drove with the sway bar, with any crank the truck had no give and rode rough as crap. Sway bar off and it was much better.
I might try to mess with it today and see what I can do about getting it re-bent to dodge the swaybar how it is now - I was really hoping someone had done it the right way and had a solution, I really like my plates and bought the set of 3 back in the day when they were $1k+ for the set.
I appreciate the feedback guys, gonna try to mess with a few different options and see what I can get in line.
