The annoying chime thingy
10K views 18 replies 15 participants last post by  MotorCityRado
so i was out doing some running around and i got in my truck and started it, it did the usual chime 3 times to let me know to put my seatbelt on, then it chimed 5 times fast. later i shut the truck off, and it chimed 5 times fast again, then i got out, closed the door, and locked it, and it chimed again. when i went back to the truck, i unlocked it and it chimed again, and kept doing it at these times. i checked my headlights, there are no lights on in the guages. anyone experience this before?
#14 ·
x eleventy billion!!!!!
My first mod was to get rid of that annoying POS.. every modern car I've owned that's the first thing I've yanked - hate 'em with a passion :tdown:
#12 ·
my schoshe caused the ABS module to loose class 2 data from the BCM and I also was unable to pull any codes with the POS installed! I am currently looking for an alternative chime modual
#15 ·
yeah if all it does is make door chimes, than I may just leave the SOB out of there, but than I would have to run a direct wire from the fuse box for RAP right?
#19 ·
After installing an aftermarket radio and the aftermarket chime modual mine is acting backwards. Normally if you lock the doors with one or both doors open you get the doot doot doot sound. For some reason now mine does that everytime I unlock the car instead. if really anoyying and i have no idea why its backwards now... and the doors are perfeclty shut. damn its annoying!
