Throttle body gasket
4.4K views 11 replies 7 participants last post by  $inner
When I remove the throttle body for cleaning, is there a gasket? Should it be replaced? A part number..??
#2 ·
No gasket. At least wasn't on mine.
#8 ·
If it isn't too late-
No gasket, just the o-ring as mentioned above. You can remove it and clean it down too, just wipe it down. But when you install, I'd suggest tightening it down in a criss-cross pattern or so. Tightening it down in 2-3 steps will help ensure it's seated squarely and evenly. And it doesn't take much, so don't over torque it. A 1/4" drive socket will be your friend.
