I am using wheels and sensors from a 2011 Yukon. They are a different style (rubber stem vs threaded metal stem).
Yes, I did try the relearn procedure, but could not get any acknowledge beep from the truck. I also tried the "quick" relearn procedure where you just drive without letting air out.
The tire shop guy used his scanner and says all four are still active, but his tool can only reprogram a certain brand of sensors (available for only $74 each!). So he said to check with the dealer to see if they can do it.
Why can't my truck just learn these new sensors? Any advice to force it?
Thanks,
Thanks,
