I apologize about this thread. I've searched and read until my head hurts. I've found nothing that seems to be relevant to my Canyon's current demon possession.
Here's the skinny:
When pressing my brake pedal, my left signal indicator will slightly illuminate and will chirp the first tone for the "dinger". If I release the pedal, the light goes dark and I get the second chirp. If I have my left signal actuated, it will pulse as it should. If I depress my brake pedal, it will cause a rapid cycle of the signal. It hasn't done it on the right signal, yet. However, sometimes my right signal will stop chirping and only flash when the pedal is pressed.
This is an intermittent issue. I have unplugged the battery and let the truck sit for a few hours before reconnecting the battery. I've replaced both brake pedal switches and am leaning towards a failed BCM, or a shorted/loose ground somewhere.
I know this issue has had the snot beat out of it on this board, but every attempt I've tried has proven futile. I appreciate any insight, especially from the GM technicians on board.
This only happens when I press the brake pedal.. and it only happens intermittently. Also, it will cycle between "normal" and "wtf", even during the same press of the pedal. It's like there is a wire dancing around making contact and then losing contact. It's driving me up a wall, guys. I'm about to kill it with fire.
Thanks.
Here's the skinny:
Thanks.
