yank 3000 stall INSTALLED
3.7K views 7 replies 5 participants last post by  countryboyqball
Well i ordered the yank 3000 stall and friday it came in, well friday me and my buddy pulled an all nighter and installed it! we also tried to install the 2nd and 4th gear servo's and that was major fail from the mechanic i had do it lol. so i have to decide now weither to sell them or keep them and order new o-rings...im still putting 150 miles on it (only have 110 left haha) but whoa what a difference it makes with normal driving, and just feeling all around 100x better. it'll def be sweet with the size cam im going with. goodbye tires. next thing asap is to do a trucool transmmission cooler!
im going to do a track run when it opens before doing the cam install to see how much the stall alone helps (with street tires). now i get to finish working on my other project ive been working on thats almost complete
#2 ·
what happened on the servo install ? fail ?
#5 ·
o-rings got messed up and 1 broke, so i have to order new 0-rings for it and im gonna order my trans cooler at the same time
i have to finish my center console for my gauges to install the trans temp gauge and all
#4 ·
Here you go Darek!
•A stall converter does what a torque converter does, but has a modified stator that requires a higher than normal rpm before it locks up. Lock up is determined by the amount of rpm the engine can achieve with the brakes on. Stall converters can be purchased with a wide range of stall from 1200 rpm to 6000 rpm. Ideally for the best launch or acceleration, the stall should be 80 percent of the rpm necessary for maximum torque. Stall converters are generally used in racing applications or towing applications, but it is not unheard of for a high horsepower street vehicle to be equipped with a stall converter instead of a torque converter.
if you need help installing your servo kit PM me and I can shoot you some advise, they tend to be pains in the asses I had to take a few cuss/smoke breaks when putting mine back IN but there are a few little tricks that you can get them back in.
what kit did you order?
#8 ·
alright thanks i will
i ordered them from oregon performance transmission
#7 ·
A little Vaseline on the o rings makes it easier to install them.:thumbup:
