So lately I have been interested in a V8 swap after finding out my truck (08 LS extended cab 2.9L 5spd) has zero power when it comes to merging or trying to pass. I have been seeing the LS is the way to go. My question is what have people found out with keeping their 5spd or just keeping it manual. (Right now the plan would be to keep the LS completely stock as its already almost double the power).
On to the real question. On my 85 Toyota pickup I swapped in a 1UZ V8 out of a Lexus SC400. The 1UZ is the Toyota version of the Chevy 350 or the Ford 302. Now the way I swapped the motor in was slightly different then normal. The 1UZ was mounted to the front crossmember, not the frame. So what I ended up doing was cutting the front frame completely out and building a new frame to match the SC400. The front crossmember was bolted onto the SC, so by building a new frame I made a "bolt in" 1UZ swap. The bonus to doing that was I now had an independent front suspension with coil overs. I did the same thing with the rear end. I now had IFS and IRS on a 1985 pickup. (It was pretty much a newer Toyota Supra pickup. With a 300HP V8).
Does anyone know if the GTO, camaro or Corvette have similar front and rear crossmembers? Would I be able to "unbolt" the front and rear end of the corvette and "bolt" it under our truck?
I'll post pictures of my Toyota after I get home.
