2006 Colorado – Automatic transmition
This is related to This Thread but I started a new one since that subject would be very misleading.
Any ideas? The one thing I can think of is a metal shaving got into the ignition housing far enough and just right to short something out. ...well that and the possibility I’m just not doing something right.
Also, is this the best catagory for this? It's under "Aesthetics" but I didn't see anything more appropriate.
- The original Cylinder had been drilled out. I replaced the cylinder (without tumblers so I could see if the truck would start before jumping through the hoops of getting it coded. )
- As soon as I hooked up the battery the dome and floor light came on. No key in the ignition.
- The new cylinder seemed to function mechanically, it would go through the various positions correctly, but nothing happens when turned to “start”. Truck doesn’t try to turn over, lights stay on.
- Nothing changes as I move the selector through the various gears.
- I tried removing the new cylinder to see if it was somehow causing the dome/floor lights to stay on but they did not go out.
