+22mm offset wheels
1 reading
12K views 46 replies 16 participants last post by  DBNissan
i dont know the back spacing, but i was just wondering what +22mm offset wheels would look like on my xtreme. can anyone help?:shrug:
#20 ·
IIRC 20x 8.5 with a +15mm offset is almost perfectly flush with the fender w/o flares.
so that means a 20x9.5 with a +15 offset would stick out about 1/2". the additional 7mm of offset is about 1/4".
this means they would stick out about 1/4" w/o fender flares.
#21 · (Edited)
I dont know about that cause my 20s are 23 offset and they are just inside the fender. I looked them up and they are a 8 wide rim. Maybe the extra .5 on that rim moves them out a bit :shrug:
#23 ·
+22mm on a 9.5" wide wheel will be CLOSE with the Xtreme flares.
I have +10mm offset with 8.5" wide wheels and sit flush with a 255/35.20 tire. I actually had to flare the passenger side bed-side out to clear the tire.
According to Wheel Offset Calculator, the 22x9.5 with +22mm offset will stick-out 1mm past my wheels.
#25 ·
I'm running a similar size.
18x10 +38 all around with a 275/35/18 in front and a 285/35/18 in the rear.
Wheel at full lock.
When the sidewall rolls over under under extremely hard cornering it will rub the swaybar, and sometimes at full lock the tire will rub the passenger side brake line bracket. Other than that they fit fine. If my math is right the size/offset you listed will sit farther out about 1/2". Depending on what suspension setup you run and the tire size you go with they may or may not stick out. It will also depend on if you run flares and which kind you run.
#26 · (Edited)
What about an 18x9 wheel with 0 offset and 5 inches backspacing or
a 17x8.5 wheel with 5.34 backspacing, +15 offset on a z71? I like American Racing ATX wheels with teflon, but these numbers also confuse me.
#33 ·
The 22x9.5 +22mm wheel you are looking at will stick out 1 mm past where my wheel sits. That's a negligible amount.
I gave you a pic and the answer in the post below. What more confirmation are you looking for??? :shrug:
ok if its a 8.5 wheel with 22mm offset=5.63 backspacing
if its a 9.5 wheel with 22mm offset= 6.13 backspacing
Someoen toss me up the xtreme 18x8 offset was it 30mm? Ill figure this all out for you this is all i do on s10s/silverados/colorados/and trailblazers ss all day long
I believe the Xtreme 18x8 has a +23mm offset
#31 ·
Tony I believe its 28 mm, same for the ZQ8 wheels!
#35 ·
I know it old but i have the same promble 22x9 with a 22mm offset would it fit fine in xtreme flares need help, getting this wheels in 3 weeks and dont wan any problems. thanks
#36 ·
A 9" wide wheel with a +22mm offset will sit 6mm in from where my wheel sits in the pic in the above post
#44 ·
This is a 22x9 with a +30mm offset on Xtremehawaiian's truck. These are my old wheels so I'm sure of the size and offset.
The wheels you're getting would sit 8mm further out which is only a little over 1/4" so they should be pretty close to these.
Thanks this make me fill a little better :thumbup:
if anybody has pics with a +22mm offset can you post them thanks :D
#47 ·
with a 265 you *might* have to flare the passenger side bedside out a little. The tires will definitely rub down the inside edge of the flares.
