2nd gas tank
2K views 5 replies 2 participants last post by  Slowrider
Has anyone put a secondary gas tank on one of these? I was toying with the idea of putting a secondary tank in the spare tire area once I get my rear bumper made to hold the spare.
If anyone has done a 2nd tank how did you hook it up?
I was thinking of setting it up on a switch to pump into the stock tank when the stock tank gets low. I have never done anything like this before so any help anyone has would be greatly appreciated.
Thanks everyone.
#4 ·
No. I just tapped into the factory filler neck. I then rigged up a simple switch in the cab for a fuel pump. I added a couple grounding straps for the auxiliary tank. It wasn’t a very difficult project.
I also have a fuel gauge for the aux tank.
I’ll try and grab you a picture of everything in the morning.
#5 · (Edited)
This is my tank. Forgive the bad photo but I’ve got all my camping junk in the bed too.
You’ll see there are 3 lines:
One goes to the fuel pump
One is a vent
One is a return line
The fuel pump is a Carter brand. It’s overkill for a transfer pump so you could easily get away with something smaller. The fuel filter is from a 04-05 Colorado. I simply drilled 3 holes in the bed for the hoses to run through. If your wanting something pretty you’re not going to like my method. Function over form.
I used a barbed fitting that I added into the filler neck. I just cut approximately 6” out of the factory filler neck and used hose to add it in.
I then ran a switch into the cab along with the wires for the fuel gauge. I used a reed style stainless steel sending unit inside the tank. They are commonly used in marine applications.
I bolted the tank straight through the bed and put a grounding strap on two of the bolts and attached them to the truck frame.
The system has worked well for nearly 80k miles.
