I searched around but definite answers on certain combinations seems difficult. My truck is an '04 Canyon z85 4x4. I put 31x10.5 15 Yokohama Geolander AT-S on today. Stock suspension, stock z85 wheels. Tires fit perfectly without any rubbing. I still plan to crank the TB's to level it, but I don't NEED to. Now I just have to do an outer tie rod, TB crank and an alignment.
I was checking out the axle angles today also as my previous tires were heavily worn on the inside do to negative camber up front. My axles are actually headed up to the hub from the front diff., seems the TB crank will not only look better but improve my alignment specs and axle angles as well.
Posted some before and afters below.
