Still trying to diagnose this issue. I've tried shifting into 4wd probably 40 times now and not once has it gone in. Moving, stopped, rolling backwards, nothing. Turning the truck on and off while shifting into 4wd, still nothing. Checked both fuses, the TCCM fuse and the FAXLE fuse, both are fine.
I found some instructions on testing the front actuator, and I don't *think* that's my issue but I could use a second opinion. I found that when I turn the truck on I get power at the pink wire at the actuator, which is correct. When I select either 4wd option I should be grounding the light blue wire, which is not happening. The light blue wire becoming grounded operates the actuator, right? Mine isn't being grounded, so more than likely the actuator is fine it just isn't being asked to engage.
So what can cause the light blue wire to not become grounded when I'm pushing the buttons for 4wd? Is this wire grounded directly by the dash buttons, or is it grounded by to TCCM? The truck windows don't leak, it's never been flooded, and the carpet is dry so I'd be surprised if the TCCM is actually bad but I guess you never know? What else can I do to diagnose or eliminate the TCCM since it's expensive?
Does anyone know if the TCCM waits until the t-case is finished shifting to actuate the front axle, or if it's done in parallel? If one of the t-case limit switches goes bad can it cause this?
