It's not too bad. All you need to mess with is the tube that goes from the differential (Pumpkin) to the driver's side of the truck. So, you tear down the front end like you would to replace the driver's side CV axle and you take that out. Then you just go a little further into it. First, you need to make sure that's your problem. Jack up the front end of your truck until both front wheels are off the ground. Crank up the truck and put it in 4x4 and turn one of the front wheels. If the front end lock-up is working, when you turn one wheel the other one will also turn. If it doesn't lock-up, remove the front axle actuator. It's the round plastic part with an electrical plug going to it. Disconnect the wires and use a large pair of channel lock pliers to screw it out. Connect the wires back to it and put the truck in 4x4. In 4x4, the plunger will extend and in 2WD, the plunger will retract. If the actuator is working and the front end is still not locking up, you have a problem with the front actuator fork that is probably caused by worn out parts in the front axle tube that goes from the differential to the driver's side of the truck. With the actuator still out, take a screwdriver and stick it in the hole where the plunger goes and press really hard on it. If you feel the screwdriver going in and the front wheels lock-up then you need to remove the axle tube and replace some parts. Let me know what you find. I should have made a "how to" on this procedure because I can't find a video that is specifically for out trucks, so I had to watch a few on Silverado's and figure it out myself.
