Not going to argue about the operation of the PassLock System
From the 2006 GM 355 Service Manual. Accept it or not, makes no difference to me:
The Passlock™ system is provided in order to prevent vehicle theft if the ignition lock cylinder is forced to rotate. The Passlock™ controller reads the coded Passlock™ data signal. The data consists of a voltage generated by a voltage divider network created between the Passlock™ assembly and the Passlock™ controller. If the data is correct , indicating rotation of the lock cylinder with the proper mechanically cut key, then the Passlock™ controller sends a password to the powertrain controller via serial data to indicate that fuel should be delivered to the engine. The Passlock™ controller also interfaces with the driver displays subsystem to indicate, via a security telltale, the Passlock™ subsystem status and acute subsystem failures.
The components of the Passlock™ system are as follows:
• The ignition switch
• The body control module (BCM)
• The security indicator on the instrument cluster
• The engine control module (ECM)
Ignition Switch
The ignition switch contains the wiring and electrical switching portion of the column mounted ignition assembly. The ignition switch includes wiring pigtails which connect it to the base of the column connector. The Passlock™ sensor is an internal resistor within the ignition switch.
The ignition switch receives a 5-volt reference from the body control module (BCM) via the ignition key resistor signal circuit. When in the start position, the 5-volt reference travels through the Passlock™ sensor within the ignition switch. This creates a unique voltage value which is returned to the BCM via the off/run/crank voltage circuit.
Body Control Module (BCM)
The body control module (BCM) contains the logic of the theft deterrent system. The BCM provides the 5-volt reference to operate the Passlock™ sensor. The BCM also measures the voltage of the off/run/crank voltage. The voltage measured will indicate whether the Passlock™ sensor has been activated and whether the resistance value from the sensor is a valid value or the tamper value. If voltage measured is in the valid range, the BCM compares this voltage to a previously learned voltage code. If the voltage codes match, the BCM sends a serial data message containing a password to the engine control module (ECM). If the voltage codes do not match, or the voltage is in the tamper range, or there is a circuit fault, the BCM will not send the correct password to the ECM, and the vehicle will not start.
Engine Control Module
The engine control module (ECM) contains the remainder of the logic of the theft deterrent system. If a serial data message containing a valid password is received from the body control module (BCM), the ECM will continue to allow the fuel injectors to operate. The ECM will allow the fuel injectors to operate until it decides there is no valid password coming from the BCM. If the ECM does not receive a serial data message, or receives a serial data message with an incorrect password, the engine will crank and will not run or will start and stall immediately.
