Aftermarket Fog Lights switched by High Beam Activation
1 reading
16K views 19 replies 9 participants last post by  BackInBlack
Hello Nation,
I am hoping that someone can point me in the right direction because I have an idea of what I want I just don't know how to get there.
Currently my truck does not have factory fog lights. My goal is to buy some fog lights that fit the factory fog light location and wire them up so that they are switched on by the high beams coming on. I don't want to over load the high beam circuit but rather would like for there to be some sort of sensor that monitors the high beam power so that when it senses power to my high beams it tells my aftermarket fog lights to also turn on.
Does anyone have an idea on where I should begin? i'm sort of a wiring rookie although I did wire up my aftermarket head unit with heat shrink terminals :th_woot:
I want the fog lights (actually they will be driving lights) for the extra light output and I would only need them during high beam driving anyways, and I think this could prevent the need for an in cab switch and would keep the wiring completely under the hood.
PS: I'm not worried about this being illegal for having too many lights on at once.
#3 · (Edited)
I am electrically challenged as well, so I left the driving light install up to my local stereo shop. I asked the installer to wire the driving lights in such a way that they come on with my parking lights, so there is no extra switch in the cab. When I turn on the parking/head lights, the driving lights come on as well.
Honestly though, if you do the high/low headlight mod, you'll have more than enough light to see down the road.
http://www.355nation.net/forum/how-lighting-electrical/7626-how-dual-high-low-headlights.html
Also, you'll likely see little to no benefit using driving lights in conjuction with the highbeams because the factory fog light location is too low to to the ground. For optimal distance lighting, the lights need to be higher up.
It's a fairly simple process, you just need a relay, they can be bought at just about any parts store or on ebay for a couple of bucks, just ask for a single pole/single throw or single pole/double throw bosch style relay, just make sure and get one that will handle the amperage of your new lights. If i wasn't at work on my phone i could get you a diagram on how to wire it up. Depending on which lights you buy, they may come with the relay and instructions on how to wire it up. If you lived closer i could do it for you, i probably have everything you'd need setting on my work bench.
#7 ·
If you wire the fog lights directly to your high beams, you'll overload the circuit.
As Cuzican said, you need a relay. All a relay is, is an electronic switch that switches automatically when it senses voltage. The relay is actually 12V hot all the time, until it senses voltage from something to activate it. In this case, it would be your high beams.
When you flip your high beams on, a wire will send 12V to the relay, triggering it. Then, the 12V from the battery direct lead will turn on your fog lights. When you flip back to low beam, the 12V is lost, causing the relay to close. This will kill the 12V connection from the battery, and your fog lights will go out.
Here's a picture.
SWEEEEEET! I think this is something I can do too! Thanks for the diagram!
Yeah I never wanted to tap into my high beams for power but I knew there was a way to use something (a relay) as a switch that would be activated by sensing when my highs were on!
#20 · (Edited)
Relay can be wired in on either wire going to your high beam bulbs. Remember a relay is just a switch. When high beams are on both sides of the bulb socket become hot with voltage. Just a thought though not sure if high beams are activated by a switch to ground. Check bulb socket to see if voltage is present on either terminal.
