Ok so I'm thinking it's time to bleed my brakes, and atleast flush out all of the old brake fluid. My truck is a 2006 and the brakes have never been bled. I read that the old fluid can develop a high copper content that will harm brake components so I'd like to flush out all of the old and refill with fresh, while bleeding my brakes in the process.
I have two quart bottles of brake fluid so that should be enough. My understanding is I need to start at the right rear wheel, and work my way closer to the master cylinder, doing each wheel at a time? I also read to put a small block under the brake pedal to keep it from dropping all the way to the floor which can cause damage to the master cylinder also?
Gonna have a buddy pump the brakes while I attempt to keep from taking a bath in brake fluid. I bought a small piece of vacuum line to put over the bleeder so the old fluid can squirt in a bottle so I don't get it all over me and so I can dispose of it properly.
Any other tips? I've never bled brakes before, but it dosen't sound too hard. I'm just going to take my time with everything and have a couple beers under my belt by the time I get finished.
