So I finally installed my new wheels. They are 33x10.5x15 BFG AT KO's on 15x8 pro comp rock crawlers 15x8 3.75 BS. Everything went pretty smoothly during the install. I flipped my ball joint and installed a Suspension Maxx spacer. The issue I'm having is with my alignment. My truck is in the proper caster and toe ranges, but I can't seem to get rid of my positive camber. I am aware that it has to do with the UCA and the amount of crank i have (right around 3.5" crank). I have around one degree of positive camber on both front wheels. Acording to the suspension shop the camber adjustment is maxed out.
So my questions are:
1. So I be concerned with tire wear if I continue to run my current setup?
2. Is there any other option to reduce the positive camber without deloading the torsion bar?
Here are some pictures for refrence:
