Crappy radio reception, any fixes?
18K views 11 replies 9 participants last post by  SYNNER
In my wifes jeep and my work truck f150 I can get all the local stations cleAr and I can get them for a large distance away.
With my Colorado the local channels go in and out and I have to use the scan feature when I am on a trip. It didn't get any better or worse when I switched from stock to pioneer headunit
Any known fix
#4 ·
LMAO.
Antenna base could also be at fault if cleaning the threads don't work. Poor connection at cable side
#7 ·
He probably didn't get the GM to aftermarket antenna adapter so the outer shield isn't making contact. I just threw mine together without an antenna adapter for a few days while I waited for it to be delivered and I would only get 2 stations that were a couple towns over clearly and all the others were crap.
#12 ·
The problem we see at the dealership with torrents, equinox, and NBS equinox is the coaxial and the antenna base need replace. Also a possibility of a poor connection at the base where coaxial connects.
