Driveshaft safety loop
3.9K views 8 replies 7 participants last post by  rfross
Is anyone running a driveshaft safetly loop used to prevent the driveshaft from flopping around (and potentially pole vaulting the truck) if the front U-joint breaks on a regular cab truck? If so, can you post up some pix of how you mounted it?
My regular cab has a frame cross member between the transmission cross member and rear axle that should prevent the driveshaft from dropping to the road but it could still flop around pretty violently if the front U-joint were to break. I need to install one for my trip to Bonneville this year as the land speed racing class that I will be running in requires it.
I haven't done a test fit yet but I'm thinking that I can take one half of the safety loop and mount it over the crossmember I mentioned to contain the driveshaft. And I'm also looking to see how others have done it, if there are any that have!
Bob
#4 ·
Incorrect Mr. Moz. Brewer15650 broke his driveshaft while on a dyno a few years back. Had catastrophic effects as well. Punctured (full) fuel tank, damaged both cab and bed. He ended up having a new drive shaft made, rather than going with an OEM replacement.
Bob
is your truck a full blown power house that needs one if not don't even think of one
maybe reading isn't your strong point. :shrug:
For the loop, I'd go ahead and mount the full loop in front of or behind the crossmember you speak of. Just using half the loop could give the tech guys a reason to give you a hard time about it.
Thanks for the info guys. I need to drain and refill my rear axle this weekend so while I've got the truck up in the air I'll be looking over the safety loop possibilities, too.
Thanks KB for the photo and plan. That's one beefy loop!
