Just finished my electric fan installation and thought I would share it with the group.
Derale dual speed fan/shroud kit part number 16822.
First speed is thermostatically controlled. The second speed is controlled by the AC or manual override toggle.
Truck heats up much quicker in the cold mornings and doesn't sound like a school bus like it did with the clutch fan.
Used a 200 deg on / 185 off thermostat inline with the bottom hose.
I didn't cut anything on the truck and the shroud installs like the factory unit.
Here is a link to the fan kit that I used...Derale Cooling Products 16822 Derale High-Output Single RAD Fan and Shroud Kits | Summit Racing
Here is a link to the thermostat kit that I used...Automotive Engine Radiator In-Line Hose Fitting Water Temperature Thermostat Sensor Fan Switch Kit
Here is a link to photos...Electric Fan Installation 2012 Colorado
