Fog light wiring harness
19K views 18 replies 9 participants last post by  CaddyGuy
Well I made a quick FOG light wiring harness for the silver Colorado today and had a question.. Amberado is mailing me her OEM fog light connectors and so while I was waiting on them to arrive I started on the harness. The OEM's show black and purple coming outta the connectors. I assume black is ground but wanted to make sure so I knew when they get here. Shouldn't matter but I have seen wires grounded to the chasis of the fog light housing in lieu of the bulb socket. SEE attached pics. The only remaining line to run is from the passenger side fog to the driver fog. Should make the install go alot quicker though. Many thanks for any input.
#5 ·
Ok next question, I'm just trying to figure it out. How are you wiring it up: with a toggle switch, or just hard wiring to where the fogs come on when you turn the lows on.
I am going to add a blue led mini rocker switch under the parking brake latch handle so I get this glow from under the handle when its on. I am adding the blue led footwell lights and a modified dome light with a switch so I can use the dimmer to control the footwells without the dome coming on. SOoo everything should look alright and I wont mess with the factory look. Another added advantage is I can use the fogs along with the brights if I need to.
#7 · (Edited)
Keep an eye on the switch. In the past I've had several different toggle type switches pretty much melt on me, when being used on fog lights, but that was in my younger years before I learned of this thing they called the relay. Those little switches don't handle the continuious current very well.
#14 ·
The first pic in the red truck is where the OEM switch is located...Beware it is an input to the BCM which then fires the lights 200 + to install to OEM vs 30 for a retrofit like I did. The other two pics are where I located mine to maintain the factory look and not get stupid with non OEM switches.
#15 ·
Damn I don't know how I missed this one Clint, but ver clean install!
#16 · (Edited)
Thanks buddy, I placed the **** azz poor boy schematics in the relay tutorial if anyone should need them. Btw i went back and added a relay, old men forget to turn em off at times lol..The silver truck front end looks alot different now
#19 ·
Sorry for bumping an old thread but I recently learned relevant information that I think should be included regarding use of fog lights with bright beams.
Check your state regulations, it may be illegal. It technically is in my state.
