How To: H3 Gauge Cluster
1 reading
50K views 70 replies 39 participants last post by  1BADI5
#1 · (Edited by Moderator)
A 355nation How To presented by:
1BADI5
Project Name:
H3 Gauge Cluster Install
Project Description:
Replace the factory/stock 355(Colorado/Canyon)gauge cluster with a gauge cluster from a H3 Hummer(345).
Skill Level:
Easy
Make: Chevrolet
Model: Colorado
Year: 2004
Engine: 3.5L
Transmission: Auto
Power windows: Yes
Sun Roof: No
Tools Needed:
1/4" drive Ratchet
1/4" extentions, 4-6" should be enough
1/4" 7mm socket
worklight, with extention cord(if needed)
Dremel tool, with cutoff wheels and sanding drum
Blue painters tape
Project Time:
2 hours or less.
NOTE: these times can very depending on your skill and tools. It took me a little over an hour the first time (spent more time taking pictures). BUT then when I removed this cluster and installed it in my members truck....yep 15 minutes start to finish.
Project Cost:
H3 Cluster- $25-100 used/new
painters tape and misc Dremel accessories
H3 Gauge Cluster Install:
Ok I'm going to write this up so a caveman can understand and be able to excute w/o question. I know most reading this will know alot of this information like the back of their hand. But this is intended for the members that are not so familiar with these mods.
1. The outter surround for the cluster pulls right off, start at the top and work you way down
NOTE: Dropping your steering wheel and shifter down(Auto trans.) will be helpful!
2. Make note of the circled areas below, there will be a total 4, 7mm screws to be removed.
3. After all 7 mm screws are removed, pull the cluster out and unplug it. Set cluster aside.
Well heres what this is all about...the H3 Cluster. With some minor cutting and grinding, this will almost fit like a glove!
4. Now your will need to cut off the top mounting tabs on the H3 cluster as where the cluster will not fit in with them.
This picture show what I had cut off and I smoothed it out with a sanding drum on my Dremel. At this point the H3 cluster is pretty much ready to go. You might need to tweek things here and there on your 355 as needed. Now its time to dive into the dash!
5. Cut the highlighted areas as needed in your application.
NOTE: Numerous trial fitting will be key to doing this right. (I was not going to load 18 pics. of me doing my trial fits)
Ok the highlighted area above is a point of interest. It can be difficult to get the bottom of the H3 cluster in place w/o cutting down these plastic tabs. It can be done, but why risk breaking your new H3 cluster if you can make a few cuts and be good to go.
The picture above shows one tab completely cut and the other not. This picture was just a visual aid for where and what you need to do!
See how the cluster will drop right into place with the lower tabs cut...but we are not done yet!
Ok we have the bottom of the cluster fitting into place, but now you will notice that the top part of the cluster needs some fine tuning....yes, more cutting and grinding(sanding).
6. Carefully cut, grind or sand these problem areas until you are satisified with the overall fitment of the H3 Cluster.
NOTE: How the top left corner of the cluster and dash were rounded off. You might have to repeat this same step on the right side of your cluster/dash.]
7. After all adjustements are made via cutting, grinding or sanding; reintall the cluster only using 2 of the 4 original mounting screws on the bottom of the cluster.
8. After the cluster is installed, start up the truck and make sure everything works. The cluster should also automatically update the mileage.
9. Reinstall the cluster surround in the reverse order of Step #1. Starting from the bottom and working your way up.
10. Sit back and enjoy your hard work.
The key point of all of this was to make this H3 cluster fit in a 355 as if it was stock. Yeah you can just break the top tabs off and jam it in there, but it will look like shit. Take pride in your work, than brag about how you installed a Hummer H3 cluster in your 355. Those non-355er's will be impressed!
#3 ·
I didn't know this was on here already, as where its a work in progress. I have all the pics ready and everything else. I will be at a wedding this weekend, So I will not finish this until Sunday night or later. So stay tuned, you will not be disappointed.
Jeremy
#5 ·
FYI a H3 circuit board will work in the colorado. I'm currently using one, however.
The Up Shift light for the manual transmission will not work (dont miss it)
The DRL will not illuminate. (dont really need it)
The fuel gauge will read different due to the sweep on the H3 cluster being slightly different from the colorados. (I've managed to get mine within 1/2 gallon.)
Ok guys I will work to finish this up tonight after work. I wish I could upload pictures at work, beceuse this would be done already. I will work it tonight though!
#12 ·
Alright guys its complete!
Let me know if I need to add anything else!
#14 ·
Thanks!
#16 ·
bout time! lol
this works like a charm....like he said, 15 minutes and we were done with my truck.
o, and if i can add something: if you buy a h3 cluster with MORE miles on it than are on your truck you will have to wait for the mileage to reach what is on the cluster before it starts reading again. If you get a cluster with LESS miles on it than on your truck it will jump to the mileage on your truck.
#17 ·
Excellent point Chris!
Good looking out!
#19 ·
Thanks, just trying to help you guys out!
#21 ·
Thanks James:thumbup:
I spent a fair amount of time studying write ups from other members. I wanted to make sure that my write up was up to the 355 Nation standard.
#23 ·
Thanks man.
If you'd be interested in one let me know. I can do one up for you then at teh same time do a write up:shrug:
Jeremy
#31 ·
Any chance of getting the pics back up? I'm working with a company that should be able to get rid of the tmps error for us non tps guys.
#32 ·
Just hoping pics might come back again. Really need them......................Help!
#34 ·
Ok thanks for the heads up, I will get them fixed soon!
#36 · (Edited)
I will try to repost the pics for this over the weekend.
I need to see what the actual issue is and if need be found out which external hard drive I have them on.
Update: some how the links got screwed up. I started to fix it, but I need to be up in a few hours so I will finish it off tomorrow! :cheers:
#38 ·
this is a super easy mod to do... you dont really need the pics to do this, when you go out to put the cluster in it become pretty odvious what needs to be dont, i can say this have just done it a few days ago. also the pics you really need are still there.
#39 ·
Thinking about picking one of these up, any chance the pics may return? Monkey see, monkey do... :eek7:
