Ok I've been searching and searching for the past week or two and have yet to find the answer or solve my problem. Here's the deal, I have an 05 Canyon w/ the 3.5l, I was installing a new aftermarket intake tube only replacing the resonator box, got everything put back together and took it for a test drive. Truck felt great, no problems, everything seemed perfect but when I parked the truck I noticed the idle felt horrible so I look under the hood to find that the hose from the valve cover to the intake had come loose and was open so I immediately hooked it back up. Still rough idle. I then took the intake off and reinstalled the stock resonator box, still nothing. I pulled the exhaust cam actuator sensor being my symptoms sounded like that was the problem and sure enough one of the screens was missing. I then replaced the ECAS with a brand new one, still rough idle! So I finally decided to take it in to the dealership to see if they could test it thinking it could be the head but the mechanic (after testing the truck) told me it was the exhaust cam actuator and something about my timing being off at idle. Not the part that everyone replaces but the actuator itself. I have no clue what part he's referring to and he couldn't provide me with a part number for some reason so I then took the truck home because they wanted another $380 to run more tests just to try to find out for sure the problem..
After taking it back home, here are some of my tests/replaced parts:
Compression test:
Cyl #1 210
Cyl #2 215
Cyl #3 200
Cyl #4 210
Cyl #5 210
• Found a leaf stuck in my MAF so I carefully pulled it out and cleaned the MAF w/ sensor safe MAF cleaner.
• Changed spark plugs (AC Delco iridium)
• Seafoam'd gas, oil, and vacuum lines
• Cleaned throttle body
• Changed exhaust cam actuator sensor (as noted above)
Results:
Truck idles SLIGHTLY better.. It still feels like it's either got a huge cam or a terrible miss and the truck idles like shit, shaking pretty bad.. Once I take off the truck is fine, I didn't have much of a loss in fuel economy, doesn't miss, nothing. Only thing that seems off is that the VVT doesn't seem like it's kicking in. Either that or the truck just has some loss in power in the high rpms but it's not a huge loss, just noticeable. Is there maybe a chance I got a faulty ECAS from the parts store? Idk what else would cause this problem and I really need this fixed ASAP. Any and all suggestions are gladly welcomed. Thanks 355!
Compression test:
Cyl #1 210
Cyl #2 215
Cyl #3 200
Cyl #4 210
Cyl #5 210
Results:
