heres what alldata says to do
Oil Pressure Diagnosis and Testing
* Tools Required
* J 21867 Pressure Gage and Hose Assembly
* J 42907 Oil Pressure Tester
1. With the vehicle on a level surface. run the vehicle for a few minutes, allow adequate drain down time (2-3 minutes) and measure for a low oil level.
2. If required, add the recommended grade engine oil and fill the crankcase until the oil level measures full on the oil level indicator.
3. Run the engine briefly (10-15 seconds) and verify low or no oil pressure on the vehicle gage or light.
4. Listen for a noisy valve train or a knocking noise.
5. Inspect for the following:
o Oil diluted by water or glycol (anti freeze)
o Foamy oil
6. Remove the oil filter and install the J 42907.
7. Install J21867 or equivalent to the J42907.
8. Run the engine and measure the engine oil pressure.
9. Compare the readings to Engine Mechanical Specifications.
10. If the engine oil pressure is below specifications, inspect the engine for one or more of the following:
o Oil pump worn or dirty
o Oil pump screen loose, plugged, or damaged
o Oil pump screen O-ring seal missing or damaged
o Malfunctioning oil pump pressure regulator valve
o Excessive bearing clearance
o Cracked, porous, or restricted oil galleries
o Oil gallery plugs missing or incorrectly installed
o Broken valve lash adjusters Repair as necessary
11. If the wading on J 21867 or equivalent is within specifications, inspect for the following:
o Plugged or incorrect oil filter and/or malfunctioning oil bypass valve
o Malfunctioning vehicle oil pressure gage or sensor Repair as necessary
