Pod gauges.
1 reading
11K views 25 replies 14 participants last post by  boosted5
I'm sure someone has done this but anyone have pod gauges on steering Column or pillar? If so can you post pics and how hard is it?
Sent from AutoGuide.com App
#5 ·
Only gauges I have seen on the steering column is a scan gauge that 06Stinger installed. Full out pods would look stupid there and would block the view of your other gauges.
#11 ·
Re:
well I integrated mine into the cluster bezel
Sent from my C771 using AutoGuide.Com Free App
#18 ·
Gauge Pod for Dash Bezel -- Saw this I think on Coloradofans. Once I do a little sanding & some primer and paint it'll look good. Used 2" PVC pipe, took ~2hrs shaping & cuttings, and then used some plastic-to-plastic epoxy to glue it together.
I did the same as 1BADI5 -- really good location IMO. I was debating about doing dual Aeroforce w/ the second on the RH side but was wondering how much a pain clearance for the auto shifter would be.
1BADI5, i see you've replaced the auto shifter -- does that provide more clearance over OEM for a gauge there?
#21 ·
I have an auto and added dual guages.........I have about an 1/8" between the SSK shifter and the guage bezel......lots of prep work, measuring and mock ups ensured a perfect fit.
#25 ·
great job. looks awesome. i always thought the dash guage would look sick and you totally confirmed my wonder.
#24 ·
Re: Pod gauges. i made a killer prototype
my step dad makes props for movies and basically he makes exact replicas of guns and different things actors run around with or hit other actors with. so basically i had him take some of these gauge pods from a new mustang that are somewhat egg shaped and fabricated them into the pillar of my colorado and then make a clean mold of that so that it looks like the pods came in the pillar with a factory look. if anyone is interested, and i get enough hits, ill post some pics of my prototype and you guys can tell me what you think. i only made a 3 gauge pillar pod but if all goes well with this, ill talk to the admin about letting me hook you guys up.
