Question about tilt wheel and cruise
2.8K views 10 replies 4 participants last post by  dlucas
Went to the junk yard today and they had a reg cab with cruise control and a tilt wheel. Does anyone know if it would be that difficult to change mine over to have these options???
#2 ·
hmm i don't see y not.. prob gonna need the harness and the cruise control motor.. gotta do some research on it.. if i find anything i'll let ya know
#5 ·
adding the cruze might be alot of work. prety sure there is no "motor" or vaccume control because we have a drive by wire system. the cruze is gonna have to talk to the bcm/pcm, and this may have to be programmed into the system.( i know because my cruze dosent work after my PCM Forless tune.) i know it can be done but its gonna take some program work. good luck! keep us updated!
#8 ·
I would assume if you had the cruise tables in the transmission control then it should be plug and go... What you would have then, is the ability to notify the PCM of cruise operation.. Just a theory since all files I seen have the cruise function in the PCM. If you remove the steering wheel, you might want to disable the airbag system.
