OK, so i bought these shackles off a member here on the site, in the OP it said they were from smaxx but there was a later edit that i failed to notice that said they were actually spring tech, the website they were from was suspensionmax.com with one x so their not SMAXX.. here is the link..
04-10 Chevy Colorado 2" Rear Lift Shackles
my question is, how the hell do these things "lower or lift" a truck, i will write out the instructions on the sheet and maybe one of you guys can help me out if these things are any good or will even work...
For Shackles:
1. Place jack under pumpkin and raise rear end to relieve pressure on shocks, remove shocks from mounts and lower jack to relieve pressure on springs
2. Unbolt stock shackles both top and bottom and remove stock shackles saving all hardware
3. Install shackles as follows: Using the top hole will lower the truck approx. 2'' The bottom hole will lower the truck approx. 1 1/2''
Ok so first of all, i don't understand why the directions say Top hole; LOWER 2'' bottom hole LOWER 1 1/2, won't these shackles lift the truck? :shrug:
For Shackles:
