2008 3.7L I5 LT Crew 4x4 w/ G80 94k miles. Stock af
TL;DR
Truck shake felt in seat, not felt in steering wheel. Tires rotated and balanced a few times now by Modern Tire (where I got the tires) and road-force balanced by dealership. Problem still exists no matter what orientation of the tires. All tires at 32 psi. Dealership found brake drums were out of round and corrected, did not solve problem. Dealership inspected u-joints and driveshaft, stated no problems there either. Shocks are Monro Reflex with about 25k miles on them. Shaking peaks at around 63 mph and the gear, accelerating, coasting, or 4x4 do not alter shaking intensity.
The truck has a slight shake at 60+ mph and I am at a loss. Stock all around. You can feel it in the seat and it will visibly shake water bottles in the cup holders. Letting off the gas or applying power makes no difference. Neutral coasting makes no difference. Shake is always there at 60+ mph.
The problem started a month ago out of the blue. I noticed the shake in the seat and the steering wheel. I took the truck in for a balance and tire rotation (it was due anyways). It did help a little, they claimed all 4 tires were out of balance. Shake from steering wheel gone, but the shake from the rear was still there (to a lesser degree).
The mechanic noticed that there was still a slight shake from the rear, checked the balance of the rear tires again, and suggested that the problem may be drive line related.
So, I take the truck to the dealership. I describe the problem and stated that the balance was recently redone two times. The dealership mechanic confirms shaking at 60 mph, suggests a road force balance. We go ahead with the road force balance and the problem is still there, no difference.
Mechanic removed the driveshaft and inspected for loose/frozen u-joints, no problems found. Then, they checked for rear drum run out and determined both rear brake drums were out of round causing rotational vibration when driving and braking. They machined both rear drums, sanded shoes, and reinstalled. Mechanic determined that this repair solved the problem.
I get the truck back and the problem is unchanged. Still felt right at 60+ mph. Brakes do feel smoother, though, so at least that's nice I guess.
Drums were replaced in September with P/N 19171781 (link) by the dealership. What I found strange is that these other drums (see picture in this link) from ACDelco have a weight on them that my stock ACDelco drums do not have. Makes me wonder if that weight is needed?
Also, could the mechanic be wrong about the u-joints? That seems to be the common culprit of shakes. Most of the threads here state that the u-joint shake only happens when coasting or under certain loads.
No carrier bearing on this model. With all that was stated above, could the u-joints still be the culprit?
TL;DR
