Long time reader, first time poster.
I have an issue that is baffling me right now, and was hoping someone could help me out with it.
I have an 04 Colorado LS, I5, with torsion bar suspension. It has been to the moon plus some (251k) and has been a pleasure to drive for the last 30k miles of ownership. Recently, however, a shake has developed that I am having trouble pinpointing.
Symptoms: When the vehicle has been sitting for a bit, for more than an hour or two, and I go to drive it, I have a shake that starts at lower speeds (around 25mph). As i keep accelerating, the issue goes away at those speeds, and returns at about 40 mph. As I continue to accelerate, the issue moves again, becoming more noticeable at 55mph and up to 70+. However, as I sustain speeds of 70 or more, the issue goes away entirely. Soon enough, I have completed a couple miles of driving and the issue is completely nonexistent. Not even a hint of shake. The issue was faint at first, but over the last thousand miles has intensified. The shake is incredibly hard to pinpoint; I cant tell if it is from the front back or powertrain. I can feel it in the steering wheel a little, in my ass a little, in my legs, everywhere.
Attempts to fix: I first went for tie rod ends as those were visibly shot. One was terrible, so I thought I had identified the issue, but upon replacing both the issue did not change whatsoever. Ball joints are good enough, no real slop there. I got under and tried yanking all over the driveshaft and had no play in the U joints. I oiled them well anyway, thinking it could be them binding, again to have no effect on the issue. The tires are relatively new (5k miles) and I did not throw a weight off the wheel. I tried increasing my tire pressures drastically, no effect. Decrease pressure drastically, no effect. Theoretically, changing the tire pressure would result in a different input frequency (generated by the road) to the powertrain and should have had some change in the symptom, whether it better or worse. But nada.
Everything I can think of going bad would persist, but the fact that the issue disappears after a short period has me very confused. As an engineer in the automotive sector, with a lot of incredibly smart resources to refer to, this is particularly frustrating. There are a million "could be"s but the fact that this thing has over a quarter million on the clock makes me very hesitant to throw money at it. I am just looking to see if anyone has had a similar issue, in hopes that I can get a good starting point.
Also, the steering rack leaks pretty heavy, I dont know if that could affect it. At this point I am not willing to count anything out. Just thought may be a useful tidbit.
Thanks to anyone who made it this far into someones first post. Much appreciated fellas.
