No, I'm buying a semi-custom independent rear suspension.
And for that I have to specify the desired track width.
I'm thinking of having the rear wheel-well openings flared a little to close up the opening some, so I would have the option of flaring it a little also. If I did so it would be only a small bit, nothing too obvious.
I'm asking the question generally.. for handling, ride, appearance..
If I can spec any width I want, should I vary from the stock track-width?
Should I bring the rears out any at all relative to the front?
Tires will be P255/55R18 / 104 SL, so section width is 10.4 inches, tread is 9 inches.
(The current wheels are 15-inch steel)
I chose these wheels:
18" x 8"
Bolt pattern = 6 x 135.00
backspace = 5.88
offset = 35 mm
(Choice of offset in either 15 mm or 35 mm).
Really, I'd almost prefer the OE Xtreme 18s.
They're 18x8 in 28 mm offset.
I can't find the backspace anywhere.
And I intend to look around at Nissan Titan wheels, but I'm getting close to time to make a choice and go with it.
