1 - 4 of 19 Posts
If you check the how-to I did on changing the carrier bearing, you can see what I did to relocate the carrier bearing and clearance for the drive shaft on mine.
You could probably shim it, I bent the mounting location up to the angle I needed, saves excess wear on the carrier bearing.
1 - 4 of 19 Posts
