21 - 40 of 52 Posts
depends what kind of stance you want. if you want stock stance, sure.
depends how much rubbing you can tolerate, what is the width of the tire, what is the width of the rim, what is the backspacing of the rim, how much youre willing to cut to make it not rub.
thats way too vague of a question.
I was able to fit 33x12.5" tires on my truck, but i have cut sooo much out of my truck and i dont have a sway bar. but i run a 31x10.5 with no problems day to day, and ive been running them since the truck was stock.
oh god. i would call you a bro, but you dont live in california, out here the only people who run rockstars are bros.
10.5" wide rim is HUUUUGE, and is gonna stretch your tires if you run a 33x10.5
it sounds like youre in for a shitload of cutting and pounding regardless
thats a 32x11, but are those street tires? ive never seen an offroad tire in that size
definately go with the 8.5" rim.
try to find something around 4.5"-5" backspacing
Not exactly. The tires and axle tube can only take so much. But it allows you to stay level and maintain control easier.
Probably not. I've had more than that in my truck.
Yeah - cubic yard of topsoil.... :D
Don't recommend it too frequently.
Approaching 2k pounds.
i have them too, took an hour to put both on. really easy. but with 33x10.5's your gonna have to cut out a metric shitload of stuff too not rub. it get a cst spindle if i were you and do it the easy way. the 33s wont rub going strait but you wont be able to turn for shit. and if you hit a hard bump your gonna be buying a new set of fenders
easy as hell. just gather all the tools you need ahead of time.
a full set of metric sockets/wrenches and you should be good.
i did both sides at the same time so i could leave the swaybar on.
Discussion starter · #40 ·
even with the 3"BL?
21 - 40 of 52 Posts
