So, I've had issues with my sunroof for awhile, sometimes it has power to the switch, sometimes it doesn't... but I pulled the motor out and tested it, it works fine...no issues there.
Fuse isn't blown, but had a LITTLE bit of corrosion on it, so I put in a new one. That is getting
power through the fuse.
So, I thought it was the switch...got a new one...still no power (well, off and on)
I'm thinking it's a bad ground....it's grounded to the roof, above the headliner, right above the windshield...
Using my multimeter, I tried different grounds, and I'm confident I'm not getting power at all....but why other times?
I also cleaned the contacts in the fuse box, opened the fuse box and checked the connector on the bottom...I;m stumped here...Any ideas?
