81 - 100 of 127 Posts
If you go to the RPO code lookup under G80,this is what it comes up with.
G80 Differential, heavy-duty locking rear
G80 Differential, automatic locking rear
G80 Differential, heavy-duty automatic locking rear
G80 Differential, limited slip rear
G80 Differential, locking, heavy-duty, rear
G80 Differential, Zexel-torsen, limited-slip, rear
G80 Rear Axle: Positraction
G80 Locking, Rear Axle
G80 Axle Positraction Limited Slip
G80 Differential, locking, rear
G80 AXLE POSITRACTION LIMITED SLIP
Typically if you see G80 in a car RPO list then it is a limited slip. If its in a light duty truck RPO list like our trucks then its a locker with the exception of the Quadrasteer equipped vehicles which got the G86 limited slip.
I understand that, but it's information from a fan site. It's a well built fan site, but if it's not owned or operated by GM (which it's not) it's as accurate as wikipedia. Just because someone built a search tool doesn't make it accurate information.
I'd like some info from GM on the exact model of Eaton Differential for every year, make and model of Colly/Canyon from 04-12. If anyone has a service manual, I'd be curious to see if the exact Eaton part # is listed, and not the GM part #. A difference in part #'s between packages or service codes could point to to some trucks running LS and others full lockers, both using G80 codes.
Anyone know what the code is for an open rear diff?
whatever, I really don't care... they wouldn't put a limited slip in a truck(except the quadrasteer ones) or a full locker in a car for obvious reasons
I agree, but dumber things have been done and it's been argued to death, here and elsewhere.
I'd like to see something from GM with the actual Eaton part #'s used so we can go to eaton and get the exact recommended service interval and fluid, with or without LS additive.
I know it's a full locker in mine, because the only time it malfunctioned in 9 years and over 200k miles was when I put mobil1 with LS additive in it. When I dropped severe gear in it, the problem stopped.
My point wasn't that you were wrong, but that you are quoting a Site without credentials. It's like saying everything here in every post is always correct and shouldn't be questioned. It's a community owned and operated site, so it has the same potential for misinformation to be restated as fact over and over again until it becomes untouchable.
Earlier in this very thread there are people who swear we have a LS diff and must use LS additive or we will grenade. There are posts stating the opposite with the same end result. Who's right?
Two of us have shown u the RPO G80 designation is simply a GM code for a traction enhanced diff, either limited slip or locking. Why don't u show us where it says G80 means locker only and G?? means limited slip only?
This thread contains a bunch of myths and misunderstandings about the different types of traction enhanced diffs, how they work and their different lube needs. One of the myths is, a limited slip diff requires a special additive. If the clutches don't "chatter" in a tight turn, the limited slip diff does not need an additive and no mechanical locking diff needs an additive. In a tight turn, I want to hear some clutch chatter/tire chirp....that way I know the clutches are tight and not slipping any more than it needs too. Why would anyone want a LS to slip more.....and that's what it does with the additive.
Holy crap, why are you taking this personally?
I'm not arguing with you. Go back and read what I actually wrote. I said on our trucks g80 was full locking, period. You brought in the RPO code from other vehicles which have no bearing on this discussion (and I assumed you were talking about our trucks)
I'm saying I would like to see what actual model number of eaton diff is in the aam800 for our trucks. People here, in this thread have argued the LS additive/full locking thing TO DEATH. This is supposed to be a site with FACTS, not conjecture.
So, to that point - and to help anyone who comes here for information and doesn't want to read umpteen pages of people arguing back and forth if our trucks need LS additive for them someone should get the documentation to back it up and POST it here for reference, since sticky threads are for REFERENCE.
I AM however saying that links to a fan site shouldn't be taken as law, and when you link to gm-trucks.com it's as reliable as Wikipedia. It's a community run site with a community built database. Your link proves that g80 is GM's code for a differential, but doesn't tell you what is inside or what the required fluids/additives are.
For all we know, some model years of trucks could have different eaton model number differentials inside the bell housings (or even non-eaton brand) than other years. G80 just means something intended to mitigate slip is there, so who says all models 2004-2012 got the same kit?
In this thread, we see an anonymous post that no one can confirm is legit saying to use 80w90 with no LS additive for all GM light trucks with a G80 RPO code. In our manuals, it just says a synthetic 75w90, which contradicts that bulletin. You can't find Mobil 1 gear lube WITHOUT LS additive (at least in my area) which leaves Amsoil and Delco.
I'm saying, with the intent of ending discussion around something that should be fact, that part #'s and official bulletins from GM (OEM assembler) and Eaton (presumed manufacturer) should be available SOMEWHERE. Anyone who has ever worked in an industry making anything knows that somewhere those lists exist and are on file for legal and liability reasons down the road, along with batch numbers and production dates/locations for what was put in our trucks with vin# references.
I'd like to see them HERE. We should have the resources to get them with the amount of experience and connections of the membership. If they are all the exact same model #, great. Then it's a simple one line post with recommendations both from GM and Eaton (or the actual manufacturer) on fluids and service intervals.
That's all. Post the facts from the horses mouth for the membership. I'm not talking about YOU personally doing it. I'm saying someone who is a member here who may be able to get that information to help the site. It exists, and it's ridiculous that it's not readily available to the public (GM's fault).
If you refer to posts 76-80 you were arguing... he said there is an LSD G80 used in cars, you said there isn't
As far as to which fluid to use its synthetic 75w-90... 80w-90 is ONLY USED IF you are experiencing axle chatter as stated in GM service bulletin #91-4-109
As far as getting the info you want... why don't you just call/email Eaton directly
I already stated I was talking about our trucks. Not cars. I'll edit the post now to clarify and make the point.
Sorry for not being clear, I wasn't really arguing with you about anything. Lots of people think our trucks have LS Diffs, and I see it in post after post without it being corrected. I was trying to make sure that information wasn't be spread since this is "The" g80 thread for our trucks.
I already emailed Eaton to find out what the g80 for our trucks actually is. If/when they respond i'll report back.
When people see the G80 video and it plainly shows "clutch packs", it's easy to see why some will call it a LSD. I have reservations that it is a "true" locking diff (like a spool when engaged), since it utilizes "clutch packs", but I guess GM can "call" it whatever they want. "Clutch packs" slip.....they are purposely designed to slip.
The G80 locker (if that's what u want to call it) in our trucks is certainly way better than any open diff could possibly be......it performs just as smooth (and hopefully just as reliable) as an open diff in normal driving......but it's far from as reliable as a LSD when it gets ragged on, especially on pavement.
Let me get this straight. In the glove box on the right side where part replacement codes are listed. It will list G80? I have a 04 Colorado crew cab 2wd ls with traction control. On my tag it lists "G80" 3/4 of the way through the second line of codes. Does this confirm a G80?
Thanks in advance.
GM uses RPO code G80 to indicate when a vehicle has some form of a traction enhanced diff. For example, when G80 is found on a GM car's SPID sticker (Camaro for example), the diff is usually a version of a limited slip traction enhanced diff. When G80 is found on a GM truck's SPID sticker (Colorado for example), the diff is usually a version of a locking traction enhanced diff. Just 2 different ways/types of traction enhanced diffs that send power to opposite wheels somewhat equally. There are numerous types of limited slip diffs as well as numerous types of locking diffs. Since the version of the GM G80 locking diff has clutch packs, it almost sounds like it is some kind of limited slip/locking hybrid.:shrug:
