Hey guys, just wanted to get everyones opinion on my truck issue im having.
It seems my truck has started a whine, I did a little research and im not hitting on anything.
All the conversations seem to lead to other conversations and no outcome.
So I checked the truck over and its not the power steering, its not the belts or pulleys. The fluid in the tranny is full and looks good.
It only makes the whine when in Reverse or Drive, it doesn't do it while in park or neutral.
So that eliminates the torque converter?
The truck has 93k on the clock, its been lifted for about 15-20k Miles, seems to have no issue shifting or with performance. Just curious if anyone else has had this issue and what was the problem, and what did you have to do to fix it?
Any help or suggestion would be greatly appreciated, thanks!
