Victims corrupted 355
54K views 474 replies 111 participants last post by  bigfoot
i thought i would throw up a build thread to keep all of what ive done in the one place so here it is!!
how she started off.
an alloy tray back work truck!
bought a bed for it
welded tailgate and handle
shortned the chassis 640mm (25 inchs), made one piece tail shaft, relocated fuel tank, shortned brake lines.
painted the bumper
roll pan
brought her a foot closer to the ground!
then i drove her and abused her for about a year or so and then the real fun began!!!
i got to head out for the night so will get to the good part tomorow! hahaha.
enjoy
stu
#3 ·
I think you should have built a long bed for it, or just left the frame and bed the way it was. :kiki:
Hey man, email me at boydsmith40@gmail.com if you want that shadow logo I did. Not sure if you wanted to use it for anything else but since you are the only one with it...
#5 ·
thanks guys
blurred - it looks too short the way it is but i have changed that up with the new frame i am building. it is about 8 inchs longer to make it look a lil more proportioned.
alot of other countries get long bed ones but GM here for some reason decided we didnt need one. its bullshit coz every other manufacturer has the option.
anyway i shortned it and made do for the time being.
also i got that shadow logo, awesome bud appreciate it, i will chuck it up now as my av.
more pics soon.
Looks good cant wait to see more :)
#9 · (Edited)
i prob have about 300+ pics that i have to go through and pic out the good ones! haha
can only image how many pics i will have by the time its done.
i got rear ended on the way home from work and decided it was as good a time as any to start what was inevitable.
i called up matt grant kustoms and got 2 full combo skins sent over. got one put on a spare tub and the other is still hanging on my wall
sold that off and made a nice lil wad of cash.
bought myself a new daily work hack, cut out all the rust and then gave it a respray
this finally gave me the chance to pull the 355 off the road and get started. id been planning this for a long time and fuck it felt good to be finally starting on it. the strip down began.
sat a spare tub back on it and pushed it outside to see how it sat metal on metal with zero suspension.
quite obviously it wasnt low enough!!! hahahha
that same day =>
pulled the front end off
stripped the interior and removed the wiring harnes
the next day i rolled her back out the shed and this is how she looked!
just over 24hours and thats where we got to.
#14 ·
ok so.... now the interesting part.
LAYING OUT THE FRONT!!
then the motor came out. sold that.
kilometers on the clock when i pulled it off the road- 33,251klm = 20,661 miles!!! fuck all!
the front end minus the motor and slammed to where the BJs bind.
then i made new upper control arm mounts to raise the upper BJ and stop it from binding.
after putting the front end through its cycles of up and down i found that it caused the wheels to pull inwards just before it layed out.
this is due to the length of the upper arm and relation to the length of the lower arm in relation to their distance apart! hahah :naughty: a head fuck at the least.
took me a while to get my head around it, i spoke to bio max about it and he helped me work it out. so off came the control arm mounts and shorter ones placing the UCA to its orignal position were fabbed and welded in.
i raised the lower BJ 2 inchs with a block moching up belltech balljoints while i waited for them to arrive and i made up shims from a solid alloy block to change the angle on the upper BJ and stop it from binding.
once i did that and played with this, and adjusted that, cut this, ground that i was about half an inch from laying on equivilent to 255/35 R22.
i finally got my belltech BJS in the mail all the way from the other side of the world
i put them in and had to do a bit more cutting here and there and then shaved down the upper shims they provide to increase the angle on the upper BJ.
after doin this the front FINALLY LAID OUT!
#18 ·
Yes Impressive, not sure what else to say.:thumbup:
Damn I'd love to have one of those right drive trucks over here.
#19 ·
NEW 3/4 FRAME :
i had plenty of time to plan this build so i knew what i wanted pretty well stright off the bat.
3x2 rails firewall back all rolled to flow. i drew what i wanted in cad and did all the figures.
next on the list was to bend them to shape. so i went on the hunt to find a company that could do what i wanted. finally one came through so we set out and did it.
this was what the end result was.
they are 14 foot long and built to lay 24s with ease.
as i built the truck to lay 24s almost the entire front end would be cut off so i thought i may aswell get rid of it and start fresh. so out came the sawzall and off it went!!
grabbed the new rails and put them under the cab to get a feel of how it would look first hand.
i was pretty happy with that but it just wasnt low enough so now it was time to remove the pinch!!! nothin beats laying hard sill so i used some rhs to reinforce the sills incase of dragging mishaps
nice and thick rhs
more on the frame tomorow.
thanks for looking guys. keep ya comments comin.
