will stock tahoe 20s fit?
8K views 16 replies 9 participants last post by  Racer X
whats up nation, wondering if these stock tahoe 20s will fit my new rado at stock ride height its 4wd
#5 ·
A 275 will very likely rub too. They rub 4x4's all the time unless they have wheels with the correct backspace. Stock wheels, not the proper backspace.
Before we get too far along that tangent, you should tell us what size tires they are and we can calculate the diameter for you (if you don't know how to do it yourself). If the above size is true, you'll need to lift the front a little bit to clear the diameter if you have a Z85. If you have a Z71, it's a little close. Those will look big on a Z85 too, like an afterthought and somebody crammed the tires under the fenders. My tire is 31.7, the size above is 31.9. I'm a 1.5" lifted Z85 4x4 and the tires look almost proportional to the truck (tires are slightly tall). Plus I have aftermarket wheels with a different backspace than stock so my 265's don't actually rub.
Shew, that was a mouthful.
#8 ·
Will not be dropping if anything want to go up a little. Still reserching that, if theres any good advice in that area might save me some time and problems want to do everything the right way
The tires most guys run is a 245/45 but that only looms good if you are dropped or planning to drop. Not too sure if your wanting to lower a 4x4, so I guess itd depend on what your wanting to do.
#12 ·
Yeah those look good on there im gonna need some more tire though and dont want to end up in the sky 6inches so im prob lookin more towards 17 now with some kind of all terrains, just seen the tahoe 20s on CL and the brain wheels started smokin.
#14 ·
YEa mine didn't either. Just relating to the fit on the fronts.
Thanks. That was before the rest of my lift. Wish they were closer I'd be interested. I sold mine and have regretted it ever since
#16 ·
1/2" spacers are needed to clear the hubs
