41 - 60 of 205 Posts
Re: Its alive!!!!!!!!!!!!!!!!!!!!
there are a few guys on the S10Forum that have BUILT 2.2's WITH turbos and STILL running 16's :lmaop:
wow, now i don't feel so bad about having no luck with my mods.
I remember i had a co-worker had one back in the day. He moved up to a heavy ass early tahoe and was so happy about the power
Discussion starter · #42 ·
hhahah yeah, you have no idea what slow is untill you've driven one..
Ive got a race this weekend lined up for it.. Ive challenged everyone on a local S/R forum to find ANYTHING slower than it..
Im gonna be running against a V8 Sequia with 9 people in it :lmaop:
I had an S10 with a 2.2....It was constantly being redlined in regular traffic just to get it moving lol
Discussion starter · #47 ·
ricky do you still need lowering stuff for that tank? my buddys got springs and blocks
what kinda of springs, what drop, for what motor?
:lmaop: THIS GUY KNOWS WHAT IM TALKING ABOUT!!!!!!!
ricky what drop DID your truck have on it, and have you ever measured fenderwell height. i have an 01 2.2 AUTO with the same SS wheels, it was lowered when i got it, not sure how much in the front though. the rear has 3" blocks and is at 29" the front is at 27.5ish
mines extended cab so i had the dreaded vibration, found the JTR pinion angle correction kit and was like PFF so today i made my own and it cured it........ only had the truck for like 3 days now........ pulling a leaf tomorrow most likely to level it out.
i need seats too, i know all the newer s10/blazer stuff will fit but any idea what years?
and dont even start talking about SLOW when you have a 5 speed, mines AUTO and extended cab...................
i'll send you a pic as soon as i get one.
Discussion starter · #49 ·
yeah post some up..
no I never measured it
its got 2in drop spindles, ZQ8 leafs and HAD 3in blocks..
im gonna do a 2in drop spring and 3in blocks.. but cant figure the vibration out and S10forum is the worst at asking questions..
WTF, it looks way lower than 2" in the front... i guess pulling a leaf would give me the same drop as you then, i was told it was 2/3. might do that today if i'm slow at work.
shim your trans up 3/4 of an inch then put the blocks back in. the pinion angle is off on ALL the s10 not just x-cabs... jacking the trans up 3/4" should take care of most of the vibration. i made some spacers to lift mine but you can use 10mm washers, just stack 7 of them and get some 10x1.5x45mm bolts to bolt the trans mount back to the trans......
i have alot of work to do before i feel comfortable posting pics of this junk.....
I think you guys need to meet up at wtracing's street racing spot and have a "slow-off"". :thumbup:
Discussion starter · #56 ·
im debating if I want to order a set of those soft 8's
17x8 and 17x9 rear...
theres a dude on the S10 with a 285on the 17x9 and it looks SICK stuff under the stepside bed
Hmmmm I wonder how they'd look on a dumped Colorado... Do they make 18's? I have a li'l plan in mind for my truck to make it a little different from the pack... ;)
