Greetz All,
Previously I had done 1" Puck Lift using McMaster Carr 10.9 Bolts no problems.. I have a PA Body Lift which I was planning on installing but had some problems with cage nuts:
When I went to unscrew these body mount bolts ; 5 of the bolts (2 front, 3 cab mount bolts) are spinning.. Cage nuts have dislogged (broke the welds) to the frame. I have tried a crap load of PB blaster on the fronts bolts w vice grips but still can't loosen the bolts using breaker bar. I haven't cut through the floor to PB blaster the cage nuts under the cab but I was planning on that (if I could get some success with the fronts; which I haven't yet).
Anyone have any experience with this, I was thinking about either sawzall'ng these 10.9 bolt heads and push up the bolts to remove and using new nuts for body mounts or either try the PB blaster vice grips method after the PB blaster has had some time to really soak into those nuts.
Any advice would be appreciated..
Thanks,
Thanks,
